Right sub box?
Username: Mwright1000
Post Number: 64
Will this box
http://www.circuitcity.com/ssm/MTX-Dual-12-Subwoofer-Enclosure-BS212S-/sem/rpsm/ oid/119724/catOid/-13094/rpem/ccd/productDetail.do
work for these speaks(2)
http://www.circuitcity.com/ccd/productDetail.do?oid=119551&c=1&cm_re=main%20marq uee-_-Buy%201%20Infinity%20subwoofer%20get%201%20free-_-Infinity%2012
Username: Dark_man53190
Post Number: 23
depends on what kind of music you listen to, what kind do you?
Username: Ford_on_20s
Jacksonville, Florida Us
Post Number: 176
oh and let me add...circuit city is a fine , fine place...always trust the nice people that work there :-)
Post Number: 26
thats true, however, you can find a better box than that other places for cheap though, correct me if im wrong?
Post Number: 178
lol but yea you're right....look around you can find cheaper
Post Number: 65
Rap. Where can I find a nice box cheap and delivered fast. I'm looking at what I will spend on shipping I'm only going to save about $10 when I can goto CC and get it same day.
Let me know. Thanks
Post Number: 27
sonicelectronix.com is one place, sounddomain.com is one place, maybe onlinecarstereo.com even has some to, im not sure about the next day thing though, but those are some examples. GOT THAT BUDDY! lol
Post Number: 179
if you're going to buy from cc then why dont you look into some cvr's...or do you want those infinity's ?
Post Number: 28
whatcha call an anorexic with a yeast infection?
Post Number: 29
quarter pounder with cheese lol
Username: Dropthatbass
Minnesota US
Post Number: 77
i would just build a box, its not that hard, and plus you could probably make it for 30.00 or under (depending on how cheap you can get your MDF board), and if you really wanted you could port it.
i made my box for my RE SX 12" for 25.00 and it was 36 X 23.5 X 13.5 or something around there and this box is massive so im guessing your better off building your own for very cheap
