Diplexer for multi LNB question
tho_x_tran
Is there a Diplexer to combine or split LNBs ? I know of only those that combine Satellite and VHF/UHF but that is not what I want. I have only 1 cable run into the house via walls.
This diplexer (if exists) will be placed outside the home and grounded, replacing the grounding block. Will that work ?
Thanks.
tho_x_tran
Need some help. Can I use the Dish SW21 switch outside the house and use it to replace the grounding block as well ? The reason I ask is I have only 1 cable run into the house.
Vknike
If you have an FTA receiver you will need a Diseq Switch 4X1, in which you will be able to connect up to 4 LNBs and run one cable into the house.
tho_x_tran
The main question is whether I can get rid of the ground block and ground just the Diseq switch OR must I still keep the ground block and run the (extra) cables from the ground block to the switch ? and all these stuff are outside the house.
Thanks for the response.
