Component speakers
Username: Mwright1000
Post Number: 22
What do you mean when you use this term and how are they different than other speakers. I have been looking at some different ones and they say component set and they have 2 speakers and 1or2 small boxes with them. What are the small boxes. Just learning all the terminoligy so bear with me. Thanks
Username: Tjmutlow
Post Number: 261
They are crossovers normally a mid and a tweet with them,
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 367
component speakers separate the mids and highs by having 2 speakers a mid range driver and a tweeter by doing this each speaker produces more clarity and SQ. with components you get a crossover to fine tune the fq cutoff for each set of speakers so that way the speakers can play in the range that they were designed for and don't have to strain to produce certain FQ.
Post Number: 38
Thanks for the explinations!
