How many Amps does an alternator need to put based on amp size?
Username: Kirbdog22
New Bern, North Carolina USA
Post Number: 70
Basically what I am asking is for amp wattages how much of the alternator does that use?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 2503
http://www.the12volt.com/info/recwirsz.asp
Username: Kirbdog22
Post Number: 71
so chauncey where could i find a replacement alternator? did you get one for your Yukon?
Post Number: 2505
yep i have a 425 amp alternator, i had a place where i live build it for me,*i think he ripped me, but whatever*lol. Alot of people on this board get theres from
http://www.excessiveamperage.com/
Username: Kirbdog22
Post Number: 72
the alternator in my blazer put 100 amps of power do you think it would be safe to run 1 RE 12.1 for awhile? I mean I don't want to be out in the middle of no where and not be able to start my car.
Username: Kirbdog22
Post Number: 73
What about capcitors and extra batteries?
Post Number: 2507
A cap will will only put more strain on ur alternator. and I doubt a 100 amp alternator will allow u to draw enough current to run the 12.1 without some problems. Plus u will need about 40 amps to run the stuff in ur car lights, ac, etc.
Username: Kirbdog22
Post Number: 74
Ok well what about optima yellow top batteries?
Post Number: 2509
It's impossible to compensate for a small alternator by throwing in a bigger battery as the battery will just be drained and the voltage will suffer, affecting your light output and overall performance. But when u get a battery get a yellow top.lol
Username: Kirbdog22
Post Number: 75
ok so what your telling me to do is just get a bigger alternator right? Ok I have found one for my car it's 240 amps. so do you think that would be good enough, b/c i thought about some where down the road to put in another SX 12 and RE 12.1 amp. so would i need anything else? or just a bigger alternator?
Post Number: 2515
That might be a strain that would be 2400+ watts. Personally i would get the biggest one i could find, just to be safe, and all u need is alternator, battery, and maybe upgrade ur big 3 and ur fine. but to run 1 12.1 that would work perfect
Username: Rovin
Trinidad & T...
Post Number: 3396
I myself 'might' end up in some poo cause my ride's stock alt is 80A & my 2 new (to be soon installed) amps has 4x20A & 3x40A fuses - i 'may' need a jumpstart every morning now ...lol......
Post Number: 2522
lol, i always that u had99999999999999999999999999999999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999999999999999999999999999999999 99999999999999999999999999999999
Username: Kirbdog22
Post Number: 76
to what size alternator should i look to upgrade (minimum amperage)? What about getting a capacitor? And all i would need would be just one batter if i had two Re 12.1 amps.
Post Number: 2530
about 325 and up, u really dont need a cap, and 1 battery would work
http://wickedcases.com/caraudio/capacitors.html
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1320
325 and up? chauncy its not so easy to find 325A alternators lol. and the price at that is outrageous. im going to get a 250A alternator amd a yellowtop and a batcap 800 to run 2 1200w amps and a 500w amp.
Post Number: 2540
i was just sayin to be perfectly safe, because who no's maybe 2400 watts may not be enough for him, he might want an upgrade.lol
Username: Subfanatic
Ky
Post Number: 4810
for a 100 amp alt u can use 80 percent of it....add a second batter and an isolator and shouild be able to use 110 percent of the alt in amps
how do you figure? if the alt puts out 100a, how are you going to use 110 and maintain a good voltage? subfanatic I think you should go back to your pot smoking ways and leave ecoustics. or at least pay back the people you owe!
Sub
scr3w you Subfanatic get out of here
Username: Insearchofbass
Post Number: 3797
I had a 100 amp alternator with a 300 rms watt amp and that dimmed my headlights a little at idle so be carefull ...and ill be honest before you go for tons of watts to get the spl you want do your homework and find out how to get it by making a well thought out and researched enclosure ....doubling your power only gives you 3 db more but a well built/planned box will give it to you by doing reasearch ....it doesnt take tons of power to get decent spl or sound quality
Username: Kravenblood
Post Number: 9
lol i was pusihing 2000 rms with my stock alternator threw my amp into clipping and blew my sub lol and i think its only 80 amp alternator biggest one i can find is 180 amp from ecessive amperage ill be getting after i get tires and my shocks fixed Oh and sub lol
