Username: Yamahabanshee1 Paulding,
Ohio
Post Number: 266 Registered: Jul-04
Friday, December 02, 2005 - 03:18 GMT Which amp should I use to push 2 12" Fusion PowerPlants that I just picked up. Which on will push the subs better! Audiobahn A8002T, or MA Audio M18831. The ma audio is mono but is it ok to bridge that amp? Thanks!
Alabama
U.S.
Post Number: 2467 Registered: Jul-05
Friday, December 02, 2005 - 03:20 GMT what are ur vc configs on ur subs
Ohio
Post Number: 267 Registered: Jul-04
Friday, December 02, 2005 - 11:16 GMT 450watts rms DVC will be wired into a 2ohm so eitehr amp will under power them a lil bit! which one do you think will be better
Friday, December 02, 2005 - 13:55 GMT I think Audiobahn will have the MA beat. I used to own an A8002T and it was a little workhorse. So go with the Audiobahn. -aLeXv305
Username: Tjmutlow Post Number: 236 Registered: Sep-05
Friday, December 02, 2005 - 14:12 GMT try something else, depending on the money you want to spend, a 1ohm mono amp preferably.
Ohio
Post Number: 268 Registered: Jul-04
Saturday, December 03, 2005 - 04:53 GMT well these are my 2 choices! thanks alex!
