Cubic Foot question?????
Username: Texas_bass
Houston, TX
Post Number: 98
The alpine SWX 12" for a sealed box volume:
0.65-1.25 cubic feet
So what cubic foot should i make the box at and i still want to have some room in the back of my ext cab and what would be the best cubic foot size
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 270
Actually 1.5-1.65 are good for 12' type X's...I think u were looking at the 10s specks no the 12s.
Username: Araknid
BOCA , FL U.S.
Post Number: 1287
says right on the alpine website "Recommended Sealed Box Volume : 0.75 -- 2.0 cu. ft" for the 12"
Houston, TX
Post Number: 100
I was looking at the 12" butnot what it says from their web sight it says
Recommended Sealed Box Volume : 0.75 -- 2.0 cu. ft.
Houston, TX
Post Number: 101
So i should do 1.5 cubic feet
St. Louis, MO
Post Number: 271
Yeah that would be good.
Houston, TX
Post Number: 102
what do you all think about stuffing a box is it really worth it or not
St. Louis, MO
Post Number: 273
If you make it 1.5 cuft you wont need to.
Username: Mwright1000
Post Number: 37
How do you figure out the cubic ft of a box?
Username: Rovin
Trinidad & T...
Post Number: 3490
http://www.the12volt.com/caraudio/boxcalcs.asp
