PIMPsTAR Unregistered guest | what amp should i use to push this sub http://www.infinitysystems.com/caraudio/product.aspx?ProdId='REF1040W'&Ser=REF&Cat=SUB its going to be in a truck if that helps and i only have one sub |
PIMPsTAR Unregistered guest | any help please |
Silver Member Username: CenusHicksville, Ohio Usa Post Number: 703 Registered: Jan-05 | kicker kx200.2 |
Silver Member Username: Graphix1Santa Rosa Heights, Arima Trinidad & T... Post Number: 142 Registered: Oct-05 | http://www.infinitysystems.com/caraudio/product.aspx?ProdId=%27REF1040W%27&Ser=R EF&Cat=SUB fixed ur link |
PIMPsTAR Unregistered guest | would an 800 watt amp be to much??? i wand a lot of bass and thanks ne$ter and dustin |
Silver Member Username: MadeupnamePost Number: 109 Registered: Sep-05 | probably wouldnt be good. id find a lower wattage amp or higher wattage subs. |
Silver Member Username: Robert_dMIA, FL USA Post Number: 407 Registered: Sep-05 | well that wont produce alot of bass but it will produce some nice little kicks try gettin another and build a ported box for them then youll have some decent bass also what 800 watt amp are you talknin about |
Silver Member Username: MixneffectOrangevale, Ca. USA Post Number: 626 Registered: Apr-05 | that sub handles 250 watts. 800 would be too much. http://cgi.ebay.com/ROCKFORD-FOSGATE-P6001-MONO-CHANNEL-600W-CAR-AMPLIFIER_W0QQi temZ5837379071QQcategoryZ64572QQssPageNameZWDVWQQrdZ1QQcmdZViewItem This is actually a 300 watt X 1 @ 4 ohm amp http://cgi.ebay.com/BRAND-NEW-2005-ALPINE-MRD-M605-MONO-AMPLIFIER_W0QQitemZ58368 29025QQcategoryZ79825QQssPageNameZWDVWQQrdZ1QQcmdZViewItem This is a 250 watt X 1 @ 4ohm. http://cgi.ebay.com/NEW-XTANT-121M-250-WATT-MONOBLOCK-AMP-SW-WIRING-KIT_W0QQitem Z5834671455QQcategoryZ64573QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
PIMPsTAR Unregistered guest | i cant get 2 of them my truck can only fit one and the 800 watt amp would be mtx or alpine or kicker the sub says the rms is 250 and max is 1000 watts so what would be the best i want it to hit hard |
