Is This Possible???
Is it possible to hook a powered subwoofer up to a stereo receiver that doesnt have a sub out on it??
Username: Graphix1
Santa Rosa Heights, Arima Trinidad & T...
Post Number: 102
yep but ur other speakers wont work cause ud be using ur headphone jack output which would shut off ur other speakers while its plugged in
just trying
If your sub has speaker terminals just use those. Run your left and right speaker wires from the receiver to the sub, then run speaker wires from the sub to your speakers.
Username: Audiowizard69
Post Number: 33
thats waht i did and i have got some killer bass now. it rocks my socks off.
