Hooking up Surround Sound to my TV - help please.
Username: Creatix
I am out of my league with this stuff. I am trying to hook up my Denon receiver to my DLP tv.
Nothing is working. Any advice and/or input is greatly appreciated!
Here are pictures of what I have..
www.gladiatornation.com/imagedump/denon_rearpanel.jpg
www.gladiatornation.com/imagedump/tv_rearpanel.jpg
This is what I am trying to do. Plug my DVD player, XBOX, future XBOX(360), PS2 and whatever else (VCR) into the Receiver. Then have one set of cables going from the Receiver INTO the TV.
I have a top of the line Monster Component cable running from the 'Monitor' component ports on my Receiver INTO the Y,Pb,Pr 'Component 1' slot on the back of my TV.
I "thought" that was all I needed in order to get the Receiver to hook up with the TV but I see nothing in both my Receiver and TV menu options...
I feel like I am missing something. Any advice on what cables I would simply need to buy and where to put them to get it all to work? Based on the those pictures - what cables would you have and put where?
Thanks!
Rob Kiel
Richard,
These links may help you;
http://www.ce.org/connections_application/
Also here is another place http://www.monstercable.com/hookup_learning/csg/
Username: Creatix
Thank you Rob
