New member Username: SarahsPost Number: 1 Registered: Nov-05 | Hi Everyone, I am in need of help and I heard this is where the experts are I recently purchased a JVC HDTV model HD56G786 and have some questions. I tried calling JVC and they were not any help at all. OK, here are my problems: I have my DVD player hooked up to the TV and when I play a widescreen DVD the picture does not fill up the screen. My DVD player is at least 5 years old. How do I get the picture to fill up the screen (oh, its a Panasonic DVD player - I dont know the model). I also have a PS 2 hooked up and the games dont fill up the screen either. I changed the settings on the PS to display in 16:9 and it didnt work. Is there anyway to change the brightness of the gray bars on the screen (I dont know what they are called). I know, I'm such a girl but I really want this to work :-) Thank you soooo much in advance, Sarah |
Bronze Member Username: The_nerdly_guyPost Number: 33 Registered: Apr-05 | Sarah, TechLore has an article that should really help answer your question. It's called "How various DVD aspect ratios will appear on your TV screen". There's a few other articles there that talk about widescreen DVDs. |
SamRyuWeb Unregistered guest | Sarah, I have the same series HDTV and you can change the screen mode from standard, full, pannoramic from the remote. It's located up towards the top of the remote, button w/ 4 arrows inside a box... hope this helps. Samson |
