Audiobahn vs. Hifonics
Username: Tonybones
Post Number: 44
I am trying to decided between these 2 amps to power 2 15" kicker 03cvr15-2.
Hifonics BX1605D Brutus Mono Block 1600W RMS 1 Ohm Stable Amp:
Brand New Hifonics Brutus BX1605D Monoblock Amplifier
1600W RMS x 1 @ 1 Ohm
1100W RMS x 1 @ 2 Ohm
550W RMS x 1 @ 4 Ohm
Super D-Class Design Circuitry
1 Ohm Stable
Frequency Response: 20Hz - 250Hz
PWM MOSFET Power Supply
Ultra Fi-MOSFETS
BRUTUS EXVP (Exponential Variable Power Supply)
Fully Adjustable Acc-Cross Crossover
Line Output for Amplifier Daisy Chaining
Simpatico Coil Design
Phase Control
Subsonic Filter
21st Anniversary Edition Heatsink Design
Gold 4 ga. Power Connectors
Gold RCA Line Outputs
Illuminated Hifonics Logo
Remote Sub Control
Dimensions: 10-3/8" x 2-5/8" x 14-3/4"
OR
Audiobahn A1500HCT 2000W Mono Hi-Current Flame Amp:
Brand New Audiobahn A1500HCT 2000W RMS High Current Series Mono Amp
State of the Art High Current Amplifier Circuitry
Regulated PWM MOSFET Power Supply for Stable & Reliable Power
Double Sided Printed Glass Expoxy Circuit Board
Signal to Noise Ratio: > 100 dB (+/- 1 dB)
10 - 20 KHz Frequency Response
Bass Knob Control with Blue Backlight Knobs (0 - 18 dB)
24dB High-pass Crossover: 50Hz - 750Hz (Variable Type)
24dB High-pass Crossover: 30Hz - 120Hz (Variable Type)
20Hz - 45Hz Variable Subsonic Filter
Bass Boss Frequency from 40 Hz - 100 Hz
RCA Throughput Connection for Easy Expansion of Amplifier
4 Way Protection Circuit. Thermal, Short, Overload, DC Offset
Dual Cooling Fans with VU Metering Response Output
Cobalt Blue Illumination and High Gloss Chrome Finish
Dimensions: 3-11/16"H x 12"W x 18-1/2"D
2000 Watts RMS x 1 @ 1 Ohms
1000 Watts RMS x 1 @ 2 Ohms
500 Watts RMS x 1 @ 4 Ohms
I am thinking about getting the AUDIOBAHN AMP.
Username: James_g
TN
Post Number: 409
Neither amp will put out what they claim. Look elsewhere.
Username: Tonybones
Post Number: 45
I have witnessed the amps on the speakers.I just want something that is going to push them.
Los Angeles, CA USA
Post Number: 852
for what subs?
Username: Killer44
Ontario Canada
Post Number: 273
if ur on a budget these would be ur best bet to go with, personally i would look @ a soundstream thats what im gunna get for my re sx12, i was previously lookin @ the other 2 but u can get one for like $300 on ebay....but if u dont want to spend that much ur lookin in the right place jsut dont go with anything like sony,pyramid,pyle....
Username: Tonybones
Post Number: 48
thanx.I am going to go with the audiobahn amplifier.I have 2 15" kicker 03cvr15-2ohm
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 2006
the audiobahn is a better amp
Username: Cyclone
Bronx , Ny Usa
Post Number: 14
I heard from quite a few people the new soundstream amps are'nt like they used to be . If you like soundstream the oldschool reference and rubicon series rock . Pure clean power just like oldschool orion amps .
