New member Username: SizeyLiverpool, England England Post Number: 4 Registered: Dec-05 | i am stuck and very confused, i bought a televison and a xbox 360 and a 7.1 surround sound. i was wondering if you could tell me if they are compatible. im sure you know the 360, my tv is on the link below http://www.argos.co.uk/static/Product/partNumber/5290176/Trail/C%24cip%3D28956.S ound%2Band%2Bvision%3EC%24cip%3D29029.Televisions%3EC%24cip%3D29030.LCD%2Bflat%2 Bpanel%2Btelevisions.htm and my surround sound is below http://www.amazon.co.uk/exec/obidos/tg/stores/detail/-/electronics/B0006BAVEI please help me. wot leads do i need |
Silver Member Username: ChitownPost Number: 533 Registered: Apr-05 | You need an amplifier |
New member Username: SizeyLiverpool, England England Post Number: 5 Registered: Dec-05 | wer do i get a amplifier from? can you give me a link dat is compatible for my systems stof? |
Silver Member Username: ChitownPost Number: 536 Registered: Apr-05 | Your problem is you bought your xbox thinking it will produce sound through the speakers. Yes it does produce sounds, much like a DVD player, but you can't hook up a DVD to speakers directly. You need amplification through a receiver or amplifier. Now your other problem is that the speakers your bought are PC speakers for multimedia. They can only work (as far as I know) with a PC sound card. I don't know of regular receivers that drive PC speakers so you have to look around. |
