Fortec background
Username: Satmaster
Post Number: 9
i was just wondering if anyone here has ever tried to change the background image on there fortec lifetime ultra, If so plz give a step by step on this process........Thanx
Username: Thill1951akalk
Post Number: 904
go away to another site!...nobody is going to spoon feed u with these 2 stupid posts of yours!...Go READ lazy SOB..
Username: Prfrmnj
Post Number: 46
If you move your TV to a different location you'll have a new wall in the background! WTFO? What kind of a question is that?
change bkgrd image
this is how you change it...right click and select properties then select change background image....if you can't do that...go to amazon_dot_com and get yourself a book of "Fortec for Dumbmies"
f3
Look for Fortecloader FannanSat STB Updater v2.0 (by BASSSEM)" here:
http://web.zackyfiles.com/secciones/dekos/fortec.htm
It allows you to change the background with any mpeg file.
Username: Thrill_is_a_fag
that fcuking website is all spic talk...I can't understand that fcuking shiite..ROTF
f3
But not everybody is as stupid as you. With your head stuck so far up yer butt, I'm surprised you can read any language
