Username: Blainew Post Number: 116 Registered: Nov-05
Monday, November 28, 2005 - 06:11 GMT if i have a two channel amp...do my subs need to be wired together...in parallel or series...or can i just wire each sub separtly to a channel?? and on a mono amp..there is only one negative and one positive right?
Alabama
U.S.
Post Number: 2268 Registered: Jul-05
Monday, November 28, 2005 - 07:04 GMT u can wire each separtly, or u could wire both subs together and bridge the amp, and some mono amps have 2 - and +, what are the specs on ur subs and amp
Username: Blainew Post Number: 118 Registered: Nov-05
Monday, November 28, 2005 - 15:57 GMT when an amp is bridged...hopw many ohm load can it take..or does it depend on the amp
Username: Tjmutlow Post Number: 211 Registered: Sep-05
Monday, November 28, 2005 - 20:05 GMT normally 4ohms
