Amp help please...
Username: Mojoracer
Post Number: 37
Can I run a powered sub off of a 4 ch amp that I'm already running 4 speakers from? And if so, how? Should I consider an amp with preamp outputs, and is there such a thing? I'd like to keep my factory head unit for the stock look. I live in San Diego and it's becoming like LA for thefts. Any help is appreciated. Thanks.
Los Angeles, CA USA
Post Number: 978
are you saying you already have four speakers connected to the amp and you want to connect the sub there as well. if so that is not a good idea. you should get a dedicated amp for the sub. you can also get the low pass filter that converts your rear speaker cable to rca cable so you can keep your stock hu.
Username: Mojoracer
Post Number: 39
So, can I run an amp off another amp if it's filled? I'd like to keep the fade button active on the HU. I haven't started yet, just trying to see what kind of options I may have. thank you Chad, I've read alot of your posts.
Username: Rovin
Trinidad & T...
Post Number: 3153
if u don't want 2 spend any more $ ,why not run 2 speakers/channel & leave 2 channels open 2 run a single DVC sub .
post model nos of your speakers & that amp
Username: Mojoracer
Post Number: 42
Rovin, I don't have the apeakers yet, but I was thinking on Infinitys 6X8 for all 4 doors with components up front. I'd also like to keep my fade button for front /back control. I can spend up to 1K on this project. I saw a 6 ch amp, but was wondering if I really need 6 ch or a 4 ch amp with a separate amp for a single sub, possibly the Infinity Baslink. Thanks for your help..
