Brand New Audiobahn A1500HCT 2000W RMS High Current Series Mono Amp State of the Art High Current Amplifier Circuitry Regulated PWM MOSFET Power Supply for Stable & Reliable Power Double Sided Printed Glass Expoxy Circuit Board Signal to Noise Ratio: > 100 dB (+/- 1 dB) 10 - 20 KHz Frequency Response Bass Knob Control with Blue Backlight Knobs (0 - 18 dB) 24dB High-pass Crossover: 50Hz - 750Hz (Variable Type) 24dB High-pass Crossover: 30Hz - 120Hz (Variable Type) 20Hz - 45Hz Variable Subsonic Filter Bass Boss Frequency from 40 Hz - 100 Hz RCA Throughput Connection for Easy Expansion of Amplifier 4 Way Protection Circuit. Thermal, Short, Overload, DC Offset Dual Cooling Fans with VU Metering Response Output Cobalt Blue Illumination and High Gloss Chrome Finish Dimensions: 3-11/16"H x 12"W x 18-1/2"D 2000 Watts RMS x 1 @ 1 Ohms 1000 Watts RMS x 1 @ 2 Ohms 500 Watts RMS x 1 @ 4 Ohms
Hmmm , i dont know, tons of guys are always bashing Audiobahn but then again Tons of guys also bash Hifonics.. i havnt seen many hifonics in action nor have i witnessed any bench test on them but most say they put out 70 percent of there rated output, but i have had a Audiobahn amp tested an it put out 2300rms which was only 100rms less then its rated output an isaac has bench tested the A8000t him self an he said it did the 800 rms it claimed but the hifonics is around 250 an the audiobahn is around 400 so i would say if you have 400 just get a kicker kx1200.1 which is rated at 1200X1 rms at 1 ohm but it actually exceeds its rated output so you would actually be able to get around 1400 rms out of that sucker an its a much more reputable name brand an they are very very reliable
