i have 2 10" memphis 15-mc104 svc 400 watt subwoofers and a boss 850 watt mono amp what is the best way to wire them and how should i regulate the amp. when i turn up the volume i really don't like the way the woofer hit.you think i might need a bigger amp. AMP SPECS max power 2ohm:850x1 rms power,4ohm:200wx1 rms power,4ohm:n/a bridge power,4oh:n/a SPEAKER SPECS rms/peak 200/400 4ohm voice coil
yeah i just want a deeper bass sound. i currently have them bridged i just don't know if i need to regulate the loss pass and input level nobs a certain way
Get a better amp (Memphis would be a good match indeed!) to begin with, but the deep bass you're looking for may also be a result of the box your subs are in...
You really cant get too much deep bass from a couple of tens . Go with some 12's or 15's for a deeper bass sound ,and without a doubt upgrade the boss amplifier .
