Wierd
Username: Hawker152
the people i no that have subs only have 10's or 12's. Is it wierd to be putting in 2 15's with a 1200 watt rms Kicker amp. Or should i sell the subs for sumthin smaller?
Username: Baseball1187
Columbia, SC
Post Number: 202
no? the sub size has no correlation with the amp
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1933
btw what kind of subs are they
Username: Hawker152
they are 15 inch Celeste's
Username: Rovin
Trinidad & T...
Post Number: 2974
never heard of it - who makes those ????......
Los Angeles, CA USA
Post Number: 836
i guess celeste makes those.
Los Angeles, CA USA
Post Number: 837
what is weird is that how did you make the question mark upside down on the title of this thread. or is just my pc that shows it like that.
Post Number: 1977
mine is upside down 2, and its not Wierd to have 2 15's, i have 4
Los Angeles, CA USA
Post Number: 847
???????wierd?
Post Number: 1992
had chad if ur running windows, click start, programs, accessiories, system tools, character map and u can drag and drop lots of symbols.©
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 582
Chris,
Are you sure those arent Cellestion 15" speakers.
Orangevale, Ca. USA
Post Number: 583
