Setup???
Username: Mellowyellow
well heres the deal, im looking to get 2 12in Solo Xs 2ohm. But i cant find any Solo X ported boxs, there all for baric L7 or L5 or would a Solo X fit? any idea where to get them online, i dont feel like giving tweeter 300 just to build me a box, im installing the subs myself and some more experinced friends. And what wiring should i get to power the Solo Xs and 2 kicker 2500.1 amps.
Username: Loudon
Post Number: 305
you better hope your upgrading electrical in your car for that kind of amperage, for that sub your gonna have to get a custom box built, a prefab box for that sub will crumble, due to the fact that most of them are cheap wood, which isnt as thick as 3/4 mdf or thicker, look into other place in ur area that can build boxes for cheaper or look at an internet place that build a box to spec for ur specific sub, a good site is woodlawncabinetry.com ... check them out
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1938
http://www.klausaudio.com/
alright thanks guys, but wut kind of amp kit would you recommend?
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 319
0/1 AWG
