Sub box tuning
Username: Cplaya280
Quakertown, PA USA
Post Number: 110
Is it better if the box is tuned at a higher hz or lower hz, so what would be better 38hz or
34hz. or 40 hz or 36 hz. the sub is a kicker l7 and I know nothing bout the tuning, im looking at 2 boxes one that is tuned at 38hz ported and one that is tuned at 32-34hz ported.
Username: Cplaya280
Quakertown, PA USA
Post Number: 112
does anybody know a website about box tuning
Los Angeles, CA USA
Post Number: 923
http://www.the12volt.com/caraudio/boxcalcs.asp
Username: Cplaya280
Quakertown, PA USA
Post Number: 113
ok i dont understand the website but does anybody know what hz is for deeper bass ported box, higher the hz or lower lets say 34hz vs 38 hz what would have the deeper bass and sound better.
Username: Rovin
Trinidad & T...
Post Number: 3087
lower the no ,lower the bass frequency
go with what the manufacturer recommends for your sub by going 2 their website & finding out.....
Username: Cplaya280
Quakertown, PA USA
Post Number: 114
lower the bass frequency what does that mean, does that mean the bass is gonna be deeper
Username: Cplaya280
Quakertown, PA USA
Post Number: 115
Ok i also just found a bigger box that is tuned at 46hz, what would be the best box for good deep bass
Los Angeles, CA USA
Post Number: 929
46 is kinda high. 33hz~36hz is pretty good.
Username: Cplaya280
Quakertown, PA USA
Post Number: 116
what is bad about 46hz im mainly looking into big spl dont care as much for sq so if i want big spl go for 33-36??
Username: Cplaya280
Quakertown, PA USA
Post Number: 117
bump
Username: Disturbedpriest
Post Number: 183
Okay i have an enclosure running at 30hz and one running at 40hz, the 40 sounds louder but the 30 hits harder, if you can grasp that. (the 40 tickles my nose the 30 sortof just drops and sounds lower) My friend is running a box tuned for 40 but he has his amp setup at 120 and for some reason it out hits my lower tuned setup and plays better on all types of music. (can someone explain that to me.)
Username: Jkidder
Spring hill, Florida Usa
my amp says subsonic filter 30 hz - 250 hz and my sub says frequency response 24-0.1 khz... do those have anythign to do with the amount of hz i need to tune my box to?
