Is my Panasonic CT-32HX42 ready for HD
Username: Shocket
I have a Panasonic CT-32HX42 which is HDTV-ready. RCN is my cable company and they have HDTV.
Do I need to buy a converter or anything to recieve HDTV on my set or will the converter box that the cable company provides be enough?
- Pete
You need a HD cable settop box from your cable company and subscribe to the HD service. If it does not provide your local network HD, then you would also need a HD tuner and an antenna to get the off-the-air signals.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 2158
bump
