Question about ohms
Username: Blainew
Post Number: 107
is it better to have a 4 ohm setup...than a 2 ohm setup...when there are more ohms...more resistence to power...wouldnt it seem that the bass would be better..more sound quality..
do ohms have anything to do with sound quality..whats better 4 ohms for your subs..or two ohms..i know they will be louder at 2 ohms..but would they sound better at 4??
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1667
it depends on your amp, and which vc configuration would be convenient for you. no real advantage to either. it's just a matter of affording you a chance to match to your amp.
