New member Username: BilgeratPost Number: 1 Registered: Nov-05 | Im in need of a power supply fo a 1995 hitachi 60sx12b rear projection tv, according to my tv repair guy its no longer available, any body know where to find one??? |
Silver Member Username: Wearenotalone69Post Number: 257 Registered: Aug-05 | 1st you need you get a copy of the service manual.. I just Googled with the search term: power supply for a 1995 hitachi 60sx12b Check out the first link. Hopefully it will list the part number, the manual is in 13 parts, so it may have a parts listing. Then Google around with that part number. Best of luck! PS: Thanks for posting the model number and YEAR the set was made in your request... Sort of "helps" to know the sets model number..year of mfg... Personally I think you're not going to find a power supply... Maybe some NOS , or a pull if if you're real lucky but I wouldn't count on it. Checked Ebay? http://www.freelists.org/archives/techassist/04-2005/msg01528.html [TechAssist] Hitachi Proj. Model 60SX12B Chassis AP63B. Dead, relay click only. Red led D975 (bright) From: "Robinson Electronics" <robinsonelectronics@xxxxxxxxxxx> To: <techassist@xxxxxxxxxxxxx> Date: Sat, 30 Apr 2005 16:54:10 -0400 Maybe you Hitachi Techs. can help me with this set? This set will not power up, I have a relay click only. The diagnostic "red led" lights up only, at first flashes a few times, then stays on bright. No green leds at all, not even breifly. I pulled the board, suspected the reg. I901, not sure. I found a 2w. power resistor (open) R903 33 ohm 2w. I cannot find any tips indicating this resistor as any common faults? Has anyone seen this before, or would it indicate a power surge damgae to the reg. I901? I have some on order, but not yet installed to try. Any help appreciated on this. Thanks. Robinson Electronics 1075 Sweeten Creek Road Asheville, NC 28803 Ph./Fax. 828 274-3787 Toll Free. 1-888 ROBELECT www.robinsonelectronics.com www.robelect.com Mailto: RobinsonElectronics@xxxxxxxxxxx |
