Chicago's Finest Unregistered guest | I kinda like the look of this bin.....it's all blue! anyhow.....i m still trying to load channels on here...we'll see what happens...I do have a question though...what's the difference when you're tryign to scan channels it has an option for either FTA or ALL or ALL + D or FTA + D??? What is that D for ??? is that for digital?? With the new bin that i just put on my fortec i dont have that "D" option anymore when scanning channels...Thanks! ALSO I am having trouble with my superdish...I wish i had a d500 that is just a lot easier i hear... My setup 121 is on diseqc 1 119 is on deseqc 2 110 is on diseqc 3 lnb power on or off??? 22hz power on or off and for which one??? THanks again! |
Silver Member Username: H3lt3r_sk3lt3rPost Number: 445 Registered: Oct-05 | @Chicago's Finest D is for data, it is used in europe to transmit teletext. If you choose FTA it will only scan for free, non-ecrypted channels, while choosing ALL will scan everything including the encrypted channels. Now to your switch setup: Since 121's lnb type is supposed to be set to 'Universal 1' you don't have to set the 22khz. for 119 set the 22khz to ON and for 110 set it to OFF. |
Chicago's Finest Unregistered guest | Great! I am going to try this out..I just picked up about 180 channels from 121 and they all work...so i guess that's a good thing (international) i am curently scanning echo 7 so we'll see if that works.. Thanks for the help! Appreciate the love! |
New member Username: PoukiePost Number: 10 Registered: Sep-05 | anyone with the fortec ultra keys??? please |
Angel_RG Unregistered guest | Get up & running with the latest N2 bin in 20 steps. I am a newbie, and on Monday 7th Nov 05 when all went down I did my homework to get things back up and running. Over a 5 hour period I read many forums, some ppl gave better instructions than others, but I did see a lack of clear instructions so many of us require. Here is my attempt: 1) First and foremost. I have a Pansat 2500a. This is a cloned Pansat. To find out whether yours is a clone visit http://www.fsfta. com/viewtopic.php?t=179 (remove the space). This site requires registration. Regisitration is free. The following instructions are for a cloned Pansat 2500a. 2) The reason some of you cannot enter N2 codes in manually is because you do not have a recent bin file. (A bin file is a binary file containing codes etc allowing us to watch satellite for free). I had a 251 bin and just like some of you could not find Nagravision 2 no matter which way I pressed the volume key. 3) How do you know the version of the current bin on your receiver? Press Menu, scoll down the System Information. If the current version of the bin has been given a meaningful name you will some some numbers in there to the effect 251a, 255, 256 or 248, or 224. 4) If you do have later version of a bin such as a 255 or 256 bin, you can enter the keys in manually. Clear instructions for that are in this thread 5) If you cannot enter N2 codes manually you need to find the latest bin and download it the receiver. And this is what I describe below: 6) Before you can download anything to the receiver you need a RS232 serial cable (straight cable not a crossed cable). You cannot proceed without this cable. 7) Then you need to locate the latest bin file. I went to www.fsfta .com (remove the space from the Web address). You first need to register (this is free). Then click on the link "Pansat 1500/2500 11 7 2005 New Keys Added No Kill". The first post on the first page has the file you need to download, namely X-85BL_051107_256_api(No-Kill).rar. (X-85 means for the Pansat 2500a, 051107 is YYMMDD for the date, and No Kill means the harmful code that kills Pansat clones has been removed). 8) It is a .rar file (which is basically another form of zip file). This cannot be unzipped by WinZip. Google a freeware unzip utility program. I used "Unzip them all" found on www.sofotex .com/UnzipThemAll-download_L9182 .html (remove the 2 spaces). 9) Once you've download the unzip utiltiy, Unzip the .rar file and you should get the bin file: X-85BL_051107_256_api(No-Kill).bin. To make sure their was no corruption in download. This file will be 640KB in size. 10) You then need a program to upload the .bin file from the computer to the receiver. There are a few Uploaders (aka Updaters) mentioned on these forums. The one I used was Blacklist STB Update v1.4. This can be found at http://ftajackass. com/html/index.php (remove the space). Click on the link Downloads. Then scroll down to subcategory "Pansat Free to Air Files". Then click link 2500a. Download Blacklist Bin Updater. Unzip the file. 11) Ok, now get back to the TV. Click Menu. Scroll down one to Parental Control, and press the OK button on the remote. Scroll down to the Second PIN and enter 0000, and click OK. Go down the Set default key, and click OK. (Some may say this step is not necessary but if you have been messing around trying to enter keys manually, then this will read the keys from the .bin you currently have installed. Like I said don't know if this is necessary but its what I did.) 12) Click Exit and number of times till you come out of all the menus. Now switch off the receiver from the switch on the back. 13) Connect the one end of the RS232 cable to the computer, and the other end to the back of the receiver. Load up the program Blacklist updater on the computer. (I disabled my wireless internet access at this point to avoid any mishaps. Wired users can disconnect the network. This is one of those steps some may say not necessary but I did it anyhow. Those of you with heavily guarded ports and firewalls may have extra problems. Turn them off if you can). 14) On Blacklist set the Comm setting to COM1 (this is default, select a different COM if req'd). Click on Select Bin, and locate the .bin file where you unzipped it to. 15) Switch on the receiver. Once the KnightRider lights have done there bit (horinzontal scrolling dash), then click on Write Bin. The .bin file is now being uploaded to the receiver. The number on the front of the receiver will match the percentage complete on your PC screen. 16) Blacklist will prompt Complete when it reaches 100%. Disconnect the RS232 cable from the computer. The receiver will have now done an automatic reset/reboot. 17) The TV screen will still read Scrambled or Bad channel. Don't panic! I also got this. Click the Menu button on the remote. Scroll down one to Parental Control, and press the OK button on the remote. Scroll down to the Second PIN and enter 0000, and click OK. Go down the Set default key, and click OK. (This step makes the current N2 keys that you just uploaded as the default keys in the receiver). 18) Click Exit a number of times to get out of all the Menus. You should now have a picture. This new bin file will also allow you to enter N2 keys in manually later on if req'd. I won't cover 'how to' on that, I think others have made good attempts at explaining that one. 19) I hope this info helps. The only credit I deserve is in taking the time to write this thread. The ppl doing the real work are the ones that write the bin files. I say a heart filled thank you to them. 20) God bless. |
Anonymous | Hi Guy,s can someone tell me how you punch in 32 numbers on a 16 number line some say key 00 first than arrow back up put in 01 is that not eraceing key,s in oo now.there is only one line unless there is new software that i dont know about.somebody must know the correct way of doing it.THANK,S <stowie> |
Chicago's Finest Unregistered guest | I have everything up and running...PPV international...everything! I really like this pantec bin...it's a lot faster than my fortec one that i was using before...Thanks for all your help H3...I really like my superdish afterall! |
dssjunkie Unregistered guest | 32 keeys go in like this 16 numbers in 00 key area, right move to 01 key area and 16 numbers go in there, press ok and done ,there is some letters to punch in also in the 32 keys you will find them by playing around with buttons but it is all there.Make sure it says nag2 in left top corner when appling the keys or it will not work. |
Anonymous | CAN SOMEONE PLEASE TELL ME HOW TO DOWNLOAD BIN FILES FOR FORTECSTAR LIFETIME ULTRA? Sorry abt the upper case! |
lost-without-tv Unregistered guest | I got the new bin and black list updater, but when I went to download it said flash failed. I have a fortec ultra lifetime and this is the first time. Can someone help me. Thanks |
New member Username: WhatzzzupppMontreal, Quebec Canada Post Number: 2 Registered: Nov-05 | whatzzz upp you guys if somebody could help me on the fortecultra to downloaded pleaseeeeeeeeeeeeeeeeeeeeeeeeeeee thxxxxxxxxxxxxxxxxxxxxxxxxxxxx |
New member Username: WhatzzzupppMontreal, Quebec Canada Post Number: 4 Registered: Nov-05 | there is no new keys poukieeeeeeeeeeeeeeee you have 2 download ur system |
Silver Member Username: H3lt3r_sk3lt3rPost Number: 469 Registered: Oct-05 | @adamoszoz https://www.ecoustics.com/electronics/forum/home-video/173994.html |
New member Username: WhatzzzupppMontreal, Quebec Canada Post Number: 7 Registered: Nov-05 | hi H3IT3r-sk3it3r......................... thx 4 responding, but still i could not find it there more detailes pleaseeeeeeeeeeeeeeeeee thxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx |
Silver Member Username: H3lt3r_sk3lt3rPost Number: 479 Registered: Oct-05 | @adamoszoz Sorry if you can't read I cannot help you, alot of people have followed that guide and got their fortec ultras working, it beats me why you can't do the same. |
Anonymous | Angel_RG you are really an angel cuz you just save my pansat 2500a. Anyway i just want to say thank you and to all of you guys out there that cant get your box working, if you have pansat 2500a follow Angel_RG instruction and you are home free. I also would like to thanks all of you guys for your hard works. |
coldgirl Unregistered guest | Fortecstar ultra lifetime. 1st time downloading fix. 1. I have blacklist updater and the new fix AL7BAR tfa ultra_050926_282_api(ntsc)(11-7-05) but the write failed. 2. Then I tried fortecstar stb updater ver 3.21 with the same fix and it comes up with flash failed. Some instructions say to turn off the receiver at the back then turn on and click download when the first green light appears and the other instructions say to turn off receiver at back, once channel comes up turn it off at front then download. I can't get this to work. Please help |
Anonymous | This will sound stupid but.... How do you get an "N" on the Pansat Menu to input the 16 digit number. |
Silver Member Username: H3lt3r_sk3lt3rPost Number: 485 Registered: Oct-05 | @coldgirl Read here: https://www.ecoustics.com/electronics/forum/home-video/173994.html |
Arsalan Unregistered guest | I have question to all those people who know how to deal with this dish and stuff especially in FORTEC FTA ***can someone me like for real if Fortec FTA receivers are working right now or not*** after installing those bin by uploader need it quick response from all of you please also send the full fortec guide installation Thnx for your help (in advance) you guys are great!!!! keep up the good work |
New member Username: KapoPost Number: 2 Registered: Nov-05 | What bin number do you need in order to get N2 screen on a Pansat 3500s? Someone told me that I needed a 119. I tried loading the 119 and the receiver locked up. After the flash the receiver would not boot up. I reloaded the factory bin and this time it powered up. Any help would be appreciated. Cheers. |
New member Username: WhatzzzupppMontreal, Quebec Canada Post Number: 9 Registered: Nov-05 | hi you guys 4 h3it3r-sk3it3r i thank u very much, u were very helpful really really thnk uuuuuuuuuuuuu ciaoooooooooooooooo |
New member Username: WhatzzzupppMontreal, Quebec Canada Post Number: 10 Registered: Nov-05 | listen up h3it3r-sk3it3r there is a guy who is always dreaming of a monkeys playing soccar night after nightand so on. till he went 2 the doc asking him what to do the doc says take this medication and u'll be fine so the guy says? is it okay 2 start the medication tommorrow. the doc says why the guy says cause the final is tonight |
Anonymous | oops!! i deleted all my channels (not a prob)but when i downloaded channels they came back in short form. is there any way i can get the long version or maybe reinstall fix. thanx |
Silver Member Username: H3lt3r_sk3lt3rPost Number: 490 Registered: Oct-05 | @Anonymous I'm assuming by long version you mean full name of the channel, which means you've had a channel list loaded onto your receiver. You can download an updated channel list from al7bar .tk , doing a blind scan will not bring channel's full name back. |
WTF Unregistered guest | Two bugs with my Pansat 2500 with new bin installed: 1) When I go to Menu, then Installation, then Antenna Setup, I cannot mark or un-mark any satellites (the box with the check mark in it). WTF? 2) Before Charlie hit our boxes, I would satellite scan and Echo 7 would only reach 73% downloading then stop. WTF? Any info will be grealty appreciated... |
Anonymous | Need some help already download bin for a fortec ultra and not all channel showed. My satellite doesnt use a diseqc switch and Im not sure if this is causing the problem. Can someone explain me how to correct this problem. Thank you |
Hawaiian Time Unregistered guest | @Angel_RG Very good tutorial. Thankyou for taking the time to read and then taking the time to help others. |
kuku Unregistered guest | can anyone help me with new keys for nagra 1 |
Anonymous | having a problem uploading latest file onto my fortec star using the using the fortec stb 3.31 it keeps teeling failed after 30seconds or so tried blacklist uploader it all starts fine then it also says failed talked to a few pros noone seems to know anyone with any input will be greatly appreciated thanks |
it Unregistered guest | new keys for nag2 |
Anonymous | Read here for new keys https://www.ecoustics.com/electronics/forum/home-video/173994.html |
New member Username: DnvrguyPost Number: 1 Registered: Nov-05 | hi guys, i do have a pansat 2700A and i used to watch all channels with bin 117 and i know i have to change it by 118. the prb is any time i tried to upload it with 118 doesnt accept it ( i mean the receiver ) even when i go and click on factory setting , i still have the old bin 117 in the sstem info. plz i need ur help, what do i have to do and how . thank u |
Anonymous | I am running a fortec star lifetime ultra made in Aug 2004 , and am using the fortec STB 3.31 loader with a USB to serial connection , the file I am installing or try to install is the right file for this receiver Al7bar FTA Ultra_050926_282t3_12H_clock_api(NTSC)however the downlood bar comes up and sits there for about 30 sec. and a screen appears FAILE TO CORRECT nomatter what I do turn the receiver upside down on and off everytime the same thing I have had some pros tell me that some of the fortecs can only be loaded from another fortec that will accept the files I would like for someone to make my day and tell me there is another solution to this madness any input would be welcome at this I already have set the receiver back to factory settings , but that did not work either |
Anonymous | I have a problem , and would like to know if there is anyone on this forum that knows more then I and some of my friends do , regarding the fortec star lifetime ultra , the unit in question is a 2004 Aug. model that will not accept the latest flash file Al7bar FTA Ultra_050926_282t3_12H_clock_api(NTSC).bin the loader is a fortec STB updater ver.3.1 using a USB to serial adapter ( the joy of new pcs. with no more serial ports} all goes well the download screen comes up fine ,but nothing happends after 30 sec. a screen pops failed to correct ( whatever correct represents} as a last resort I set my receiver to factory settings hoping that would work but to no avail if you have the answer to this problem you are a better man then me and the advise would be greatly appreciated |
Anonymous | Hello Group, I have a 2500a and I need a channal list for 61.5 in order can someone HELP me?Please |
Silver Member Username: SpankPost Number: 231 Registered: Oct-05 | For the fortec Anonymous: You could try a different loader: A different bin file: Here is the newest boot file as well: |
Silver Member Username: SpankPost Number: 232 Registered: Oct-05 | For the 61.5 channel list go here and register for free: [link removed] |
Unregistered guest | how can i get the new keys for the pansat 2500A please samo one post them or just tell me how to do it thank you |
GNR Unregistered guest | Pansat 3500s. I just tried loading the new bin but it doesn't seem to work. I get a quick 6-70 code when I first turn it on. The parental control option is blacked out...please help. |
Silver Member Username: Thill1951akalkPost Number: 585 Registered: Oct-05 | U need to all go to the mentally challenged area of the forums to find the keys and answers to 9/10 of these questions!!...U will understand the answers there,they have been written specifically for the "CHALLENGED"!!!9/10 of the posters here.. |
GNR Unregistered guest | I tried reading through all this but there is nothing specific for 3500S and the 6-70 code problem. Please point me in the right direction |
Anonymous | can somebody post the key code for me please. i want my channle back .thank |
Anonymous | cuz i don know how to download the software. can somebody answer me please. |
Anonymous | Thank you to Angel_RG for the step by step. Excellent info for those of us with little experience and nice to see good info on these forums unlike the garbage as in one of the last posts above. Thanks again |
geek 2005 Unregistered guest | um i have the new pansat 2700a and the chanels jus went out on nov.7 i tried getting the FTA files from nag2 but u need a membership of 19.99 & the hell i am not paying that so any 1 have i deas 2 where i could go to get it 4 free (i mean any websites offering that?)reply at chirayu1990@yahoo.ca |
New member Username: OanaPost Number: 1 Registered: Nov-05 | Angel_RG Can you tell me what kind of RS232 cable to get? Is it the regular one DB9 F/F cable or the USB to BD9 serial Adapter USBA/BD9N RS232? This question is also for all those that can help me. Thanks a lot. |
Silver Member Username: H3lt3r_sk3lt3rPost Number: 523 Registered: Oct-05 | @oana dobrea For 2500 you'll need a straight-through rs232 f to f, db9. For 2700a you'll need a null, cross-over rs232 f to f, db9. |
Anonymous | @ H3lt3r_sk3lt3r thank you for the info and your time about the channel long name |
New member Username: Riguitojr28Post Number: 2 Registered: Nov-05 | h3lt3r_sk3lt3r whats going on with fortec lifetime ultra |
Silver Member Username: H3lt3r_sk3lt3rPost Number: 542 Registered: Oct-05 | @Rigoberto Avila Nothing is going on, it's just working. |
Anonymous | AFTER YOU READ MY REQUST BELOW AND TO NO THANKS OF ALL YOU SO CALLED WIZARDS ON THIS SITE {AS THERE ISN,T ANY) I FIGURED OUT THE PROBLEM MYSELF THE ONLY REASON IEVEN BOTHER TO WRITE THIS IS AS THERE WERE A FEW OTHER PEOPLE ON THIS SITE WITH THE SAME PROBLEM WHO MAY LEARN FROM THIS . THE PROBLEM IS NOT IN YOUR MACHINE OR THE PROGRAM OR THE LOADER IT IS IN THE COMPUTER WHICH FOR SOME REASON IS NOT COMMUNICATING WITH THE DEVICE AND YOU WILL HAVE TO CONFIGURE YOUR SERIAL PORT OR SOMETHING TO MAKE IT WORK ,A FRIEND OF MINE CAME OVER AND IN A MATTER OF MINUTES HAD IT WORKING AND IT DOWNLOADED THE ABOVE FILE FINE IN NO TIME AT ALL WITHE FORTEC LOADER HOPE THIS WILL HELP SOME OF YOU PEOPLE -------------------------------------------------------------------------------- I have a problem , and would like to know if there is anyone on this forum that knows more then I and some of my friends do , regarding the fortec star lifetime ultra , the unit in question is a 2004 Aug. model that will not accept the latest flash file Al7bar FTA Ultra_050926_282t3_12H_clock_api(NTSC).bin the loader is a fortec STB updater ver.3.1 using a USB to serial adapter ( the joy of new pcs. with no more serial ports} all goes well the download screen comes up fine ,but nothing happends after 30 sec. a screen pops failed to correct ( whatever correct represents} as a last resort I set my receiver to factory settings hoping that would work but to no avail if you have the answer to this problem you are a better man then me and the advise would be greatly appreciated |
Anonymous | I must add THANKS TO SPANKY you tried but it is not a good idea to use differnt loaders and files as a rule Thanks anyway |
Silver Member Username: H3lt3r_sk3lt3rPost Number: 553 Registered: Oct-05 | @Anonymous Actually if would only READ!, you would've found a number of posts dealing with COM ports alone, and pardone me for asking but are you paying for the support? does anyone on this site gets payed for coming here every day to answer questions? NO we do it ALL for FREE. People are getting too comfortable with this FTA business, it's called TESTING, and easiest out of any we've had so far might I add, so why don't you TEST every possible scenario, instead of coming here and whining, because YOU yourself could not use a 'SEARCH' function. |
Anonymous | i have fortec ultra lifetime i have to turn receiver off then on to switch from 110 to 119, what could the problem thanx |
messed up Unregistered guest | could someone give me the seven set code for the pansat 2500 |
Anonymous | Hello Guys... My N2 Bin 255 on Pansat 2500A was working fine before I went on vacation last Fri. I came back today and I don't see any TV. It displays "bad signal.." screen. What has changed in the last 5-6 days? New Bin? New keys? Thanks much ! |
Silver Member Username: Thill1951akalkPost Number: 629 Registered: Oct-05 | U need to load the 256 bin and enter manually the new N2 keys which are posted at every DSS site including here withnthe How to..so go READ N2 fix is here and some other threads..latest keys and how to change keys...etc.. |
Anonymous | thill1951. Thanks for the info. Here is what I did 1. downloaded boot60.exe 2. downloaded pansat factory default bin. 3. downlaoded latest Pansat 2500 X-85-BL_051109_257_api(N) Note: this bin has N2 keys built into it. Atleast thats what it says. That's why I went with this BIN instead of 56. 4. downloaded channel list. did not work. 5. did a blind scan. still did not work. Any clues? Should i try 56? Any additional ideas? Thanks a lot ! |
Anonymous | Hi All I have a fortec ultra lifetime. I downloaded the latest bin and everything was fine. I am tring to get it started and I don't know what d to do next. I'm still getting "No signal". Also my quality is 0. What do I have to do? also what is the default PIN old & new for a fortec ultra lifetime. Thanks a lot |
Anonymous | can sombody show me how to fix my pansat 2500a please. it burn beacuse i try to upload bin |
Anonymous | OK so I got my fortec to work, but I can't get any channels for sattelite T5/KU.I use this satellite to get international channels. How can I get it to work? Thanks a lot |
Silver Member Username: H3lt3r_sk3lt3rPost Number: 563 Registered: Oct-05 | @Anonymous To get T5 you'd need a 30+ inch dish and a linear lnb. |
Silver Member Username: Thill1951akalkPost Number: 652 Registered: Oct-05 | U need to set the default keys in that pansat,before U load the latest N2 bin.. and last reboot the receiver in BACK of receiver..also I would NOT have used that boot file...playing with fire there.. BTW...what is "did not work"?...did your receiver get up and walk outside, or what happenned? |
Anonymous | Well, I used to get channels for T5 couple days ago but now they are gone. I have the dish and the liner Inb. I got the new bin for fortec and all my US channels are working fine but not my internationals channels. Do i have to change anything under Antenna Setup, like the diseq or something like that? Thanks |
Silver Member Username: Thill1951akalkPost Number: 654 Registered: Oct-05 | sometimes new bins will alter your receiver settings,so check them out again..using the REMOTE, Menu...remember! |
Anonymous | I did everything that I knew, I changed settings, I shot it off numerous times, I scanned power, satellite etc. ....But nothing. No international channels. I appreciate your help. |
Anonymous | thill1951 Thanks I am up and running with Bin 57. Needed some playing around with and few blind scans. Thanks for your help. |
sexygirl2005 Unregistered guest | hey I have a pansat 2500a and my channels do not work can anyone help me plzzzz. I heard that H3lt3r_sk3lt3r is good help plzzzzz help me. I think my program is gone. |
sexygirl Unregistered guest | Is there a web site that I can get the new program off of. And the steps to do it. |
Silver Member Username: H3lt3r_sk3lt3rPost Number: 567 Registered: Oct-05 | @sexygirl AND EVERYONE ESLE LOOKING FOR 2500 FIX. Read here: |
suryanlp Unregistered guest | thll1951 - I have been reading your posts and hope you can help. Was wondering if you knew what I have to do if I have a working pansat 2500A with dish 500 and 2 dual legacy lnbs fta. I want to replace the lnbs with dish pro quad lnb. Is the built in switch a problem, is there different settings needed on the pansat? Any help would be appreciated. |
what have you got to lose? Unregistered guest | you are the one whining h31t3r-sk31t3r if you don't want to help then don't! no one is making you help, and don't tell me you like to help people i know another one who says the same thing and like you he is always whining to. i think they call him Thill. iam not saying that you are not a helping person then i would be telling a lie. i found you and Thill very very helping people and for that i thank you both. but on the other hand if you don't want to answer someones post don't answer it. also if they don't ask the right question in the right thread don't answer the question! you and a few others like Thill control the message board and if you want to clean it up JUST DON"T ANSWER questions thats already being posted and questions that are not asked in the right thread. also if people start another thread when one is already posted don't answer it. like Thill says they need to READ,READ,READ till their eyes bleed. and soon you will see how much you have cleaned up this sight. this sight can go from being third to first because of people like you and Thill. |
Silver Member Username: Thill1951akalkPost Number: 674 Registered: Oct-05 | Hey jerk !...don't come here and tell us how to get rid of imposters like U....go away kneegrows/FCC mole/Ecoustics mods! BTW nobody was whining ...so piss off! sury...pansat 2500 has 1000x posts here on the receiver configuration and remote settings...and U physically get on your roof and change the LNB's,thats how...no secret there..no magic...no problem with the DP quad.. |
pizz of yourself thill Unregistered guest | A Thill, go take a pill, Why are you such a rude person. i didn't say anything wrong. You may known more about FTA then others, but when it come to manners you are very rude. i have a two year old son that is more polite to others then you. iam not a imposter, and i don't need to rum from the law, how about you! also i don't know this kne-grow mole at Ecoustics, and i don't know why i can't use this name and you can. the way i see it thill, if you are not apart of the solution, YOU MUCH BE THE PROBLEM. i have to things left to say to you thill, one is grow up yourself and the other is pizz off. |
Silver Member Username: Thill1951akalkPost Number: 677 Registered: Oct-05 | Im see U are using my quotes kneegrows..NO U piss off! |
You are to childish for me Unregistered guest | Ok Thill, i see that you want to care on like a little kid, i submit to your folish ways. you are what you are, you are trying to pizz me off and get me into a argument with you but i not going to play your game, you have childish like behavior and i refuse to play, go pick a fight with someone else Thill. |
Silver Member Username: Thill1951akalkPost Number: 685 Registered: Oct-05 | I have a 30 military and New England sarcastic sense of humor...so how ya like them apples...LOL...I don't want or need any beef with someone like U...I at least need a challenge...not somebody who is ALREADY "challenged" by the very simple things..go BOOT up your computer, maybe even do a scandisk and defrag... BTW...thats start...programs...acessories...system tools |
Silver Member Username: Thill1951akalkPost Number: 686 Registered: Oct-05 | I have a 30 year military and New England sarcastic sense of humor...so how ya like them apples!...LOL...I don't want or need any beef with someone like U...I at least need a challenge...NOT somebody who is ALREADY "challenged" by the very simple things, like U..go BOOT up your computer, maybe even do a scandisk and defrag...LOL BTW...thats start...programs...acessories...system tools |
intelspy Unregistered guest | I hear an echo.....szot |
Whining fool Unregistered guest | You are right again Thill, If you need a challenge iam not your man. if you beat me no big deal my wife beats me all the time. What you need is some big fish like yourself so that you can prove to everyone what a big man your are on this sight. If you are a military man like you say then our country is in big trouble. I know many military people and have family in the military and they would laugh at you general. Did they call you general in the military! If they didn't they should of because I thing you are a general screwed up person, who thinks he is something of very big importance and didn't amount to nothing more than a private. |
New member Username: KamalMontreal, Qubec Canada Post Number: 2 Registered: Nov-05 | hello anny one can tell me how to get the arbsat 2c the get the arabic channel and put them in my receiver please thank you |
Just ask the know it all Unregistered guest | Why don't you ask Thill, He knows everything. He wants to bash people and run this sight, so let him. Or just maybe Thill is having a baby fit thinking how much he wanted to be like J.I. Joe and ended up on this sight bashing people. |
Anonymous | It looks like Thill is dull and bankrupt of ideas except rudness to others. GROOOW up Thill. |
Silver Member Username: Thill1951akalkPost Number: 690 Registered: Oct-05 | I think I deserve a "timeout" from the children here who have NO clue about life!...later |
rabbit Unregistered guest | have a fortecstar ultra ver 3.21 loader and dont know what to put in the STB Model box...have a pansat 2500 which has been converted to a pantec...can anyone help me out? thx in advance |
Anonymous | latest bins, latest software for everything check it out: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5831525908%26&sspagename= STRK%3AMESE%3AIT%26 |
Silver Member Username: SpankPost Number: 294 Registered: Oct-05 | This ebay seller has never sold anything to do with FTA units ever! There are only 3 buyer feedbacks and they are for a $.01 gift certificate, a cookbook and a used car stereo. Don't be fooled into buying a unit that comes with a CD. The CD is full of things you can just get online for free. The current price for Pansat 2700s is $150US and you can get them from reputable ebay members or fta dealers everywhere. Don't get fooled by spammers, they are obviously desperate. |
Drummerboy Unregistered guest | @ h3lt3r sk3lt3r i lost the signal to dish 110. Im using a pantec ultra 2500 with an 18" direct TV dish and lnb. I tried to repoint, tried another LNB... what the heck happened??? I just put in new keys a week ago, and everthing was fine... |
Rudolph Unregistered guest | hey does anyone have the new dishnetwork keys for Pansat 2500a, thx. |
Silver Member Username: Thill1951akalkPost Number: 765 Registered: Oct-05 | no new keys...same keys since 11-07...which are posted everywhere here...also new bins 11-08 with new keys in it posted at dsstester.com...read the thread here "watch TV in 10 minutes" |
Aeyob Unregistered guest | I have A fortec Star Lifetime, But not ultra, I have seen ALLL AND I MEAN ALLLLL the links on the old posts but nothing is helping me, can u tell me where i can get keycodes or a bin file (i tried deteser-- but couldnt find it) ANYONE, PLEASE HELP. thanks |
Silver Member Username: Thill1951akalkPost Number: 795 Registered: Oct-05 | That lifetime is basically a dead soldier and only good for TRUE FTA channels and not dishnet anymore...haven't seen a new DN N2 bin in 2 months anywhere ..Ultra and now Classic NA are the things..either way, I would never own a Fortec! |
thomas edison Unregistered guest | check these sites out: www.satellite100.com |
Unregistered guest | i cant get my new fix into my pansat 2300a through my new usb to serial cable - any suggestions |
Aeyob Unregistered guest | Hi, i have a pansat can anyone tell me where to get the bin file (not detester) THANKS |
yp Unregistered guest | can someone please post the key codes for me...pansat..please... |
anonymously yours Unregistered guest | pansat files can be found at future-FTA.kom. c for k. you need to register, it's free. Make sure you don't have a clone as latest bin is said to be a clone killer. |
