Silver Member Username: Yamahabanshee1Paulding, Ohio USA Post Number: 251 Registered: Jul-04 | Is there anyway to run a 2ohm load on a SVC subwoofer! If so how do you do it! The amp is a 700watt Alpine mono block (bridged), pushing 2 12" Rockford P2's. |
Gold Member Username: AraknidBOCA , FL U.S. Post Number: 1184 Registered: Nov-04 | so you want a 2 ohm load between the two subs? What impendance are they are. |
Silver Member Username: CadillacdbHouston , TX Post Number: 245 Registered: Aug-05 | This question has been asked a thousand times lol just go here http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Single+Voice+Coil+-+4+ohms&image.x=2&image.y=19 |
Silver Member Username: Yamahabanshee1Paulding, Ohio USA Post Number: 253 Registered: Jul-04 | Thanks! Just what I needed! |
Gold Member Username: RovinTrinidad & T... Post Number: 2871 Registered: Jul-05 | this site also has a similar guide too http://www.the12volt.com/caraudio/woofer_configurations.asp ........ |
