Power Drain
K65
Will 2 amps drain more power than one amp putting out the same amount of power as the two?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1655
depends on the power supplies.
in many cases...yes
Username: Solacedagony
New Jersey US
Post Number: 647
If it came down to nothing else, then yes because of loss of efficiency.
