Switch
i put the pansat switch on the roof i got all 3 sat i only get 61.5 how come i put num1 110 i put119 2 i put numb 3 61.5 i only get 61.5
yoo
Maadarchoad did you change settings for others in your recever settings.
Username: H3lt3r_sk3lt3r
Post Number: 694
me thinks yoo is right on the money, change the diseq settings on your box to match your physical setup, 110 Diseq #1, 119 Diseq #2, 61.5 Diseq #3.
Username: Thill1951akalk
Post Number: 830
Do U have 3 LNB's on that dish?....and U sure U could align 3 LNB's correctly?...and what kind and type...and what type switch?....and FTA or Dishnet receiver?
