1000wrms subs that sound good in a small sealed box
Los Angeles, CA USA
Post Number: 747
i need suggestions on a sub that puts out 1000wrms and sounds good in a small sealed box. my budget for one sub is $600 or less.
Username: 54danny54
Post Number: 1062
ID Max
Username: Rovin
Trinidad & T...
Post Number: 2914
y not get Chauncey's cheap sub ......
Username: James1115
Wilton, Ct
Post Number: 4257
eclipse TI or ID max
Username: Hootz
Saskatoon, Saskatchewan Canada
Post Number: 34
alpine type x
Los Angeles, CA USA
Post Number: 754
james wouldn't i be overpowering the eclipse ti with a jl 1000/1?
Username: James1115
Wilton, Ct
Post Number: 4272
no it is a underrated sub I know people who have given a TI 1500 true watts as a DD and it kept on going and going and going lol! the only thing I would recomend is going slightly smaller sealed enclosure then recomended with 750 watts. As you know the smaller the sealed enclosure the more power it takes to reach full excursion.
Los Angeles, CA USA
Post Number: 758
thx. the sub i really want is the 13w7 in a prowedge box but the darn thing cost way too much. rovin told me that i would get almost the same sq with the idmax. i didn't think about the eclipse cause i didn't know they were that underrated.
Username: James1115
Wilton, Ct
Post Number: 4279
they will handle a 1000/1 without a problem. I preffer the ID max personally that sub has amazing acoustic response and will get loud aswell.
