Delete password from bluejay2
Username: Wolf67
I set a password and it's a total nuisance. how can I delete? usally it's a set of numbers or some word.
Username: Thill1951akalk
Post Number: 799
try 0000 or 1668...or just put the factory bin back on
Username: Wolf67
Thanks thill1951.... I'll give the no. a try. I assume I just enter as a new p/w and confirm and see if all goes away. AS to factor bin the manual has a caution this should only be done by a tech.. I would lose my setting but I can put them back in 5 minutes. Have I missed something here in this warning?
Username: Thehitch
Fla.
Post Number: 169
Yes wilf jest; you have missed something, the fee they would charge you!!!
Username: Wolf67
Post Number: 7
to thehitch... my setup has reset to factory setting.. what fee could be charged??
Username: Thehitch
Fla.
Post Number: 170
Hey wilf jest; I was referring to "AS to factor(y) bin the manual has a caution this should only be done by a TECH. HAVE I MISSED SOMETHING HERE IN THIS WARNING. It was said in JEST, WILF!!!
