Help with alternator
Username: Thigpen
RVA, Va Usa
Post Number: 281
Around x-mas im going to be putting in 2 10 or 12" SEs with a kicker kx1200.1 powering them. in either FEB or summer im also going to be putting in some XR650 componets and amp them. i believe that my current stock alternator on a 3000GT is 110amps. what amp alternator will i need once i put in my subs and speakers. around 240? and also i was reading that you need to upgrade your wires. im pretty new to car audio, just been reading up, and havent heard much about that. what are the 3 main wires you need to upgrade, how much will they cost, and is it something i can do own my own without f'ing it up.
Username: Rovin
Trinidad & T...
Post Number: 2759
imo - i think u can run that amp for the time being once u don't play it loudly all the time & especially if the car is not running . if u add another amp later on for comps then u will have to upgrade alt .....
Username: 54danny54
Post Number: 1039
goo place for alts www.excessiveamperage.com
Username: Thigpen
RVA, Va Usa
Post Number: 282
yea im hoping not to upgrade the alterntor for now, i wouldnt play the music loud for a while anyway just to break the subs in. if i were to upgrade my alternator when i get my componets in then what size alternator should i get?
Username: Thigpen
RVA, Va Usa
Post Number: 283
and what about the wiring?
