New member Username: JoshuaFlorence, Ky USA Post Number: 1 Registered: Nov-05 | Hey there. I just got my amp and subs. I have a C1101U Panasonic CD player and a Kenwood KAC-628 amp. I have no clue of how to hook any of this up. My friend and I tried but we couldnt get it to work. I have bought the wiring but IDK how to connect or where to connect anything. Help would be greatly appreciated. |
Bronze Member Username: BlainewPost Number: 63 Registered: Nov-05 | get it professionaly installed |
New member Username: JoshuaFlorence, Ky USA Post Number: 2 Registered: Nov-05 | I don't have the money or time to have it installed professinally. When i'm not working is the only time and when im not workign all the places are closed. |
Gold Member Username: RovinTrinidad & T... Post Number: 2755 Registered: Jul-05 | pretty simply - www.bcae1.com number 19 ...... |
Silver Member Username: Robert_dMIA, FL USA Post Number: 384 Registered: Sep-05 | dont get confused like i did the first amp i tried to install in my car ( i hooked up the +12v to the negative terminal on the battery and the ground to the chasis (which is correct) i looked at some pics and it looked like the positive battery terminal was the negative lol) the +B or +12v goes straight to the positive side of your battery , 6 inches or less from the battery terminal you place your fuse holder the ground has to be 3 feet or less and goes to a exposed metal bolt on the chasis and make sure you get a ring terminal and unscrew the bolt and put the bolt inside the ring terminal and screw the bolt back in a tip ... run the rca cables from your radio on the opposite side of your car from your +12v power wire (this eliminates noise) for speakers you simple clip the speaker off and connect the new speaker the same way for the radio i would buy a new wiring kit off ebay for about 5$ shipped and it matches the colors of the back of your new radio |
New member Username: JoshuaFlorence, Ky USA Post Number: 3 Registered: Nov-05 | well see i already have my stereo installed. i did that about 3 months ago. i just got the amp and subs |
Silver Member Username: UcfsaxmanOviedo/orlando, Fl Post Number: 300 Registered: May-05 | do you have all the wiring for the amp and a box for the subs? |
New member Username: JoshuaFlorence, Ky USA Post Number: 4 Registered: Nov-05 | yeah i have everything i just dont know how or where to hook certain wires up |
New member Username: JoshuaFlorence, Ky USA Post Number: 5 Registered: Nov-05 | thanks for the website superfly, i havent tried it out yet. i am at work and will when i get home. |
