Wut gauge
Username: Bga44
Tampa
Post Number: 157
what gauge should i use for a 1200RMS @1ohm. kicker said 1 or 0 gauge
Username: Rovin
Trinidad & T...
Post Number: 2750
http://www.the12volt.com/info/recwirsz.asp
Username: James_g
TN
Post Number: 394
I'll assume you have the Kicker KX1200.1. The terminals accept 1/0 GA. If you're using that amp alone, I would run at least 2 GA from the battery. I'm using that amp along with the KX450.2. I'm running 1/0 GA to my dist. block. I'm running 1/0 GA from the dist. block to the KX1200.1 and 4 GA from the dist. block to the KX450.2.
That amp comes with a 150A fuse, so you need to use a power wire that can carry that current at the length you're running the wire.
