Sub troubleshoot!!!!!
I have a Panasonic SC-AK78 CD Stereo System.. with a subout connection .. I bought an Acoustech Labs 10" Active subwoofer S100ETH..in the instructions it tells me to hook it up to sub pre-out.. so I hook up my sub to the subout connection of my CD stereo system..but it doesn't work..How should I connect it???
Thank You
Username: Jan_b_vigne
Dallas, TX
Post Number: 6653
It sounds like you've done what the instructions tell you. Were these instructions for the sub or the amp?
It was instructions from the sub..but it's Ok thanks for your help anyways.. i figured it out.. cuz in my system there is built in subs.. so i unhook those and hooked up the Acoustech sub instead... it sounds AWESOME!!!!!the WHOLE house shakes!! :P
