SACD Multichannel
Username: Yoramguy
I have a Sony C333ES SACD player.
I also have CD's labelled as SACD which it plays very well.
Will it play properly CD's labelled as SACD Multichannel?
The owner's manual doesn't mention anything about SACD Multichannel.
Thanks,
Yoram Guy.
Username: Arnold_layne
MadridSpain
Post Number: 428
Does it have multichannel analogue output? If not, it is only stereo.
Cheers
AL
MadridSpain
Post Number: 429
Just to clarify, I was referring to the outputs. If you meant if it can convert multichannel to stereo, I don`t know.
Username: Artk
Albany, Oregon USA
Post Number: 2270
http://stereophile.com/hirezplayers/401sony/
http://onhifi.com/product/sony_scdc333es.htm
It appears to be a 2 channel unit. Hey I listen to SACD in 2 channel even though mine is multichannel.
