Friday, November 18, 2005 - 23:17 GMT hey, i have a jeep and i was wondering if my amp (which has a cooling fan) would get better air circulation that a small sedan where the amp would be in the trunk because in the SUV you have more space for air to flow around... is their anything you can do to make air circulate batter so that your amp doesnt overheat? what about opening my back windows, so the air goes straight to the back, would that help? thanks alot
Username: Southernrebel Monroe,
Louisiana
Post Number: 1603 Registered: Mar-04
Friday, November 18, 2005 - 23:25 GMT 9 times out of 10 an amp wont overheat unless you are clipping the h3ll out of it or you have it run below its recommended resistance. what is the amp in question here? what subs? what resistance load is the amp seeing?
Saturday, November 19, 2005 - 00:16 GMT how do you know if you are clipping the subs?
Username: Robert_d MIA,
FL
Post Number: 380 Registered: Sep-05
Saturday, November 19, 2005 - 01:05 GMT basically if you turn up your volume to much and your subs start sounding really bad and producing noise more than a deep bass
Username: Jakeyplaysbass Post Number: 215 Registered: Jul-05
Saturday, November 19, 2005 - 01:23 GMT Just make sure that the amp isnt really close to anything (seats, box, floor,) on more than one or two sides. Its most likely the amp thats messing up not where you place it, however.
Username: Mikechec9 Http://www.cardomain.c...
Post Number: 1581 Registered: May-05
Saturday, November 19, 2005 - 07:54 GMT amps still sound better/produce better power while running cooler.
Saturday, November 19, 2005 - 12:16 GMT would you get better air circulation with a suv compared to a sudan? my amp is mounted on the back of my rear seat.like alot of people's
