Would this work
Username: Ford123
Post Number: 7
if i got 2 mtx 7500 12" SVC 4 ohm subs and the MTX 8001 amp would this system sound pretty loud? and also how should i position the subs in my extended cab (im eliminating the back seat)
Username: Rovin
Trinidad & T...
Post Number: 2693
Do u really like MTX as your brand or what ,ucan get Kicker compvr subs for alot cheaper .
u can get that amp but u can also buy the smaller MTX TA7801 which is about $300 less
i'd say face them forward along with the ports ....
Username: Ford123
Post Number: 8
i found 2 new mtx 7500 for about 200$$ and a 800 watt mono amp for 225$$ so will this combo sound pretty loud?
Username: Rovin
Trinidad & T...
Post Number: 2696
Ebay - u found it ?
not too bad but check this ,even cheaper & same exact wrms
http://cgi.ebay.com/12-05CVR12-2-KICKER-CompVR-DVC-800-Watt-Subwoofer-NEW_W0QQit emZ5829981349QQcategoryZ39777QQrdZ1QQcmdZViewItem
which amp is that for $225 ? .........
Username: Rovin
Trinidad & T...
Post Number: 2697
link stopped working - darnnit
anyway it was a Kicker compvr for $80 each....
