COOLTEC PROGRAM FOR DISHNETWORK?
Username: Zlatni3843
Does any one have the cooltec software for dishnetwork im not sure which model it is and does any one know where i can get the software
Need it asap.
Username: H3lt3r_sk3lt3r
Post Number: 465
Here:
https://www.ecoustics.com/electronics/forum/home-video/173780.html
Username: Digger99
earlier day i put a posted file on my cooltec pro 4000.when i turned it on it worked for about 5 seconds,now it won`t come on at all.did i get i screw up and download a bomb file?can i reflash the receiver?
dan tran
jtag it
Pollard33
how can i purchase jtag cable i have a megast pro using cooltec files
Username: Thill1951akalk
Post Number: 752
go to any DSS site and check out their sponsors/advertisers..
dan tran
or try to make your own with the mingo file...it work for me.
dan tran
Username: Thehitch
Fla.
Post Number: 151
Hey dan tran, where is the mingo file, on any paticular site. I saw a make your own jtag on another site and they were using a potato and knots tied in a wire, sounded a little far fetched for me. Thank you
Post Number: 642
Here:
http://www.dssrookie .com/forums/others/more-cooltec-jtag-info-and-files-47422.html
Username: Homer21
Lifetime Ultra Receiver
Aligned: Echo 6,8 (110) - getting reception overall
Problem: some channels indicate 85+ signal but no reception (black screen)
Already tried:
- scanned and re-scanned sats, TP, etc
- scanned using "ALL" settings
- Also note did the "fix" for the receiver (functional)
- Tried aligning to Echo 7 (119). Got no more than about 20 channels after scanning. Went back to 110. Used a meter in series for best signal
- Transferred their channel setting to my receiver - still black screens
FYI:
My brother-in-laws live 28 mile away (45km)they (w/same receiver + fix)say they're aligned to 119 (and 110 w/single LNB - I think they're dreaming) and they get more channels then I do with no blackouts (channels w/ good but no reception). Also they have a larger dish (30" vs 22")
I know I'm missing a piece to the puzzle - maybe I can't see the forest thru the trees on this one.
Anyone have any pieces to the puzzle????
