New member Username: Ford123Post Number: 7 Registered: Nov-05 | if i got 2 mtx 7500 12" SVC 4 ohm subs and the MTX 8001 amp would this system sound pretty loud? and also how should i position the subs in my extended cab (im eliminating the back seat) |
Gold Member Username: RovinTrinidad & T... Post Number: 2693 Registered: Jul-05 | Do u really like MTX as your brand or what ,ucan get Kicker compvr subs for alot cheaper . u can get that amp but u can also buy the smaller MTX TA7801 which is about $300 less i'd say face them forward along with the ports .... |
New member Username: Ford123Post Number: 8 Registered: Nov-05 | i found 2 new mtx 7500 for about 200$$ and a 800 watt mono amp for 225$$ so will this combo sound pretty loud? |
Gold Member Username: RovinTrinidad & T... Post Number: 2696 Registered: Jul-05 | Ebay - u found it ? not too bad but check this ,even cheaper & same exact wrms http://cgi.ebay.com/12-05CVR12-2-KICKER-CompVR-DVC-800-Watt-Subwoofer-NEW_W0QQit emZ5829981349QQcategoryZ39777QQrdZ1QQcmdZViewItem which amp is that for $225 ? ......... |
Gold Member Username: RovinTrinidad & T... Post Number: 2697 Registered: Jul-05 | link stopped working - darnnit anyway it was a Kicker compvr for $80 each.... |
