Im clipping my subs
Username: Killerzracing71
Fredericksbutg, Virginia United states
Post Number: 143
i have a mb quart pwe354 running at 2 ohms for 500 watts on a raa 1000 amp and i had a freind tune it and he is a dj and has a good idea of how to set it up (better then me) he says that its alright for the clip light to come on just as long as it goes out but the light is on a litte to much to me
this is how i can explain it the best take a brake light
The light stays on like a brake its clipping TOO much
the light comes on like a turn signal its okay to a point right
but mine is like right in the middle like stop and go traffic it sounds horrible too, even if its little clipping but i know that sub should sound something like the way it is but it cliping
they say the sub is about to die anyway because it sound like a cricket is in it i want to get rid of them anyway and a re sx 15 or 18 what do u think about the cliping
Post Number: 144
could this be my answer in this thread
https://www.ecoustics.com/electronics/forum/car-audio/175677.html
Username: Solacedagony
New Jersey US
Post Number: 618
I personally wouldn't ever want my clip light to come on... You might need to make sure your gains aren't too high, make sure you have reliable current going to your amp, or other things.
Check out www.bcae1.com for a little page on clipping.
Post Number: 145
i already know i dont want the clip light to come on either he says its okay but the output on that sub sucks
i might be my car its not small and has a real trunk
Username: Young_james
Post Number: 165
I'm fairly new to this, but I seriously don't think that the clipping light should come on at all. Not even a little. My $.02 worth
Post Number: 146
anyone else got some answers
Username: Tjmutlow
Post Number: 189
You should not clip your amp, it is a way of protecting itself, there is something wrong
Post Number: 147
well that sucks so now my subs really suck i thought i had some bass
i have benn riding with the subs hitting hard since monday it hits hard in the car but the sub sound like azz so what the problem them
i know u dont know it off the top but what could be some things
Post Number: 171
is the gain set too high?? Start there and see if you can get rid of the problem that way. Make sure your ground is perfect also.
Username: Baseball1187
Columbia, SC
Post Number: 185
killerZ, that is the same amp I have. Are you using the remote bass boost?
Post Number: 149
yeah its set in the middle i guess the gain is set right the ground is okay too. cuz me and my dad had grinded the metal down and we are using a 2ga power cable
baseball have you heard my offer on the re sx
is it 1ohm
