Searched and studied, would like explanation of signalling types
Hickman99
I have studied the Diseqc specs. I know that DP twin uses Diseqc and Legacy twin has SW-21 built in. What switches the Legacy?
I know the Pansat has 13/18 V capability, 22khz, and Diseqc.
Also, when I just had a single LNB on 119, was the Pansat using 13/18V for V/H switching? And the DP twin doesn't recognize that because it is "stacked" which is why everything has to be V?
And for linear LNB for T5, do they use 13V/18V AND 22khz for "low/high"?
Can someone (Thill1951) explain ALL this??
Thanks
Username: Thrill_is_gay
That fruitcake thrill will tell you to read and read some more....plus his time is way to valuable to waste on a fcuking cream puff like you...he would rather give his boyfriend a teabagging...ROTF
HonkyD!©k¹
thrill_is_gay
Even ur poor attempts of humor is sad.. You AMAZE me on how someone could have such a sad and lonely life on DAILY BASIS.....
