Bronze Member Username: PanacheBrenham, TX US Post Number: 16 Registered: Apr-04 | Ok im new to this...... which box is ported and which ones are sealed? |
Anonymous | wow realy new at this its ok i we were all new at one time ok a ported box has a hole in it with a tube that is cut at a certian langth to make the sub put out certian frequencies a sealed box has no holes and no leaks and can act as another spring to the driver and is tunes normaly by the size of the box its self |
Bronze Member Username: PanacheBrenham, TX US Post Number: 17 Registered: Apr-04 | Thanks Anonymous, I guess the box I have is sealed. What would I do without you? lol |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 2321 Registered: Dec-03 | Jason, try www.bcae1.com gets a little technical, but tells you everything about car audio you need to know if you plan to get into this as a hobby. |
