SOME HELP PLEASE?
INAFIA
is there really a noticeable difference in a walmart wiring kit and a lets say kicker wiring kit? is there a difference in using an inline fuse and block by ur battery as opposed to a regular 100 amp U shaped fuse?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1600
all wires are the same, u should just get diffrent rca cables
Username: James1115
Wilton, Ct
Post Number: 4223
you can get higher amperage glass fuses and also with the glass they stay dry always unlike the u shaped that are not sealed.
Username: Nutty91rs
Bloomington, Indiana USA
Post Number: 176
I've not ONCE had a maxi fuse fail and I've been running them since before they became widley avaliable. Alot of automobiles use Maxi fuses for there high amperage requirements. Now AGU glass fuses on the other hand I've seen these do everything from warp inside from heat and lose connection to the solder at the ends melting out. AGU fuses are about like the old glass fuses in 70's automobiles, antiques. The Wal mart wiring kits are Scoche; they're good kits though the kit that looks like 4 gauge is actually a 5 gauge kit (you'll never notice a difference). The RCA's are thin but they work perfectly fine, just be careful not to yank on them, or pinch them. I personally prefer the smaller RCA's because they're easier to fit under carpets. The only thing I hate about buying a 24 dollar kit at Wal Mart as opposed to spending over 60 for the same kit at the local car audio shop is that Wal Mart consumes all and if given enough time will put the local car audio places out of buisness.
Los Angeles, CA USA
Post Number: 544
get the jl audio wiring kit. its good.
Username: Rovin
Trinidad & T...
Post Number: 2607
there was an episode on SOUTH PARK about the 'great walmart' - it was so funny ........
Post Number: 1627
alot of people use this
http://www.knukonceptz.com/
Username: Cadillacdb
Houston , TX
Post Number: 176
The Link Below is to the Best Deal ive ever seen on a Zero Gauge Kit
http://cgi.ebay.com/Audiopipe-3000W-0-Gauge-PK-3000P-Amp-Kit-NEW_W0QQitemZ582893 1105QQcategoryZ79815QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Houston , TX
Post Number: 177
Also ...The only one ive ever used from Wal mart was about 4 years ago an it was a 4 Gauge FX Dual AMP KIT for like 40 bucks an it wasnt bad but i dont know if they sell FX anymore
Username: Rovin
Trinidad & T...
Post Number: 2634
Audiopipe wires apparently don't last long @ all cause i recently bought some of their cheap @$$ rcas & used it twice for bench testing ,when i went to install it in my ride 1 of the @#$%! jacks stopped working .
I asked my buddy who does alot of installs if thats common with audiopipe rcas & he said yes -so i had to go buy another set but a different brand .
Try Lightning audio for some fairly good econo wiring ........
Username: Mute_000
Swakopmund, Namibia
Hi it is not a glass, u shape or inline fuse that matters. Take 2 U shape 50A fuses and connect it parallel with 150A wire from the bat to the amp.
The stronger connectoin you have the lesser voltdrop
Houston , TX
Post Number: 180
Then my Audiopipe Suggestion was a BAD Idea as Supafly has just let you know ... But SuperFly have u tried Audiopipe wire or just the RCA's, Only wondering, i myself have never tried Audiopipe i just thought it seemed like a Good Deal on a Zero Gauge Kit seeing as How most dont go for anything under 100 bucks..Even if you Buy some Q power wire its gonna run you 40 to 50 bucks for the wire alone
