im planning on getting the orion 1200D which is 1200watts rms at 1ohm and i was gonna get 2 alpine typeR's but i was wondering if i should get 4 alpine typeS's instead cause they are 300watts rms each so it would equal 1200 and the type Rs would only equal 1000... would it be any louder with 4 or no?
if you get 4 subs, do you space to put all of them in you cavalier? that is a lot of cu ft. a 1200wrms amp works really nice with the Rs. they get really loud.
yea im pretty sure i would have the space cause i would build a box in my trunk, i dont care if it takes up the whole trunk i just want what will sound better... check out my other post i just saw a good deal its titled "should i take advantage of this deal?????" leave some input on that one for me thanks
