How do I go from mpg to vob?
Username: Lily_hewson
Post Number: 12
Hi. I just downloaded a file that I wanted to burn onto a DVD. The file is in mpg format. I have Nero Software and it will only burn DVD's if they have a Video_TS Folder. I'm assuming this means that it has to be in vob format. Is there a way, using my Nero software to make it a vob file? If not, is there any free and easy software that I can use?
Username: Rowlandbrown
Post Number: 14
Get WinAVI Video Converter. It is not free but very cheap and worth every penny. Very easy to use and does everything just as you need it!
Username: Samijubal
Post Number: 1879
TMPGEnc will convert virtually all types of files. Most Pegasys products have a 14 or 30 day free trial.
