New member Username: YoramguyPost Number: 2 Registered: Dec-04 | I have a Sony C333ES SACD player. I also have CD's labelled as SACD which it plays very well. Will it play properly CD's labelled as SACD Multichannel? The owner's manual doesn't mention anything about SACD Multichannel. Thanks, Yoram Guy. |
Silver Member Username: Arnold_layneMadridSpain Post Number: 428 Registered: Jun-04 | Does it have multichannel analogue output? If not, it is only stereo. Cheers AL |
Silver Member Username: Arnold_layneMadridSpain Post Number: 429 Registered: Jun-04 | Just to clarify, I was referring to the outputs. If you meant if it can convert multichannel to stereo, I don`t know. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 2270 Registered: Feb-05 | http://stereophile.com/hirezplayers/401sony/ http://onhifi.com/product/sony_scdc333es.htm It appears to be a 2 channel unit. Hey I listen to SACD in 2 channel even though mine is multichannel. |
