RE MT12
Username: Rickeyd87
Post Number: 54
would a Hifonics Generation XX Hercules amp be good enough to push a RE MT12? i only have $500 to spend on an amp...that amp is 2000 watts RMS into 1 ohm...or is there a better amp out there for less than $500? if so which amp?
Username: Rickeyd87
Post Number: 55
or would i just be better off getting two RE SX12 and running them each to a Hifonics 1605D amp? both tuned to 35hz? would that get louder than the one 12" MT ran to that Hifonics Generation XX Hercules amp?
Username: Rob_preg
Royal oak, Michigan United states
Post Number: 207
hifonics is basically the cheapest amp youd wanna consider for that kind of power. Most say for a quality amp, you should expect to pay 1$ per 1 watt.
Username: Rob_preg
Post Number: 208
you really dont want a cheap amp, not putting out clean power, to a good sub like that.
