One antenna / two receivers
Username: Wazup
I have a Fortec Star Lifetime ultra and one DISH pro 500 antenna towards 110 and 119, How could I hook another receiver using the same antenna?
And
When I disconnect the box, for the occasional upgrade, and I connect it again, it completelly looses the 110 channels. The signal stength looks good but I get not signal. Then a couple of days or weeks later image could be seen on the 110 channels, Is that normal?
Thanks
wazup
