New member Username: A187sensesPost Number: 1 Registered: Nov-05 | Hey whats goin on... im pretty new to car audio stuff... ok i want a pretty dam good system nothin amazing tho... i need some advice here... i wanna get two JL 12W3v2 subs and i wanna get one 500/1 jl amp... is enough power??? will it sound pretty good?? ive herd them before but not inside a car or even my car which is a toyota highlander... if it is enough power then im gonna replace my stock radio/cd player with the alpine cda 9855 head unit... if its not then i might go with the 1000/1 and the two subs minus the alpine head unit and jus keep my stock cd player... |
Gold Member Username: RovinTrinidad & T... Post Number: 2644 Registered: Jul-05 | those subs are 300wrms each so that 500/1 amp will do ... |
New member Username: A187sensesPost Number: 2 Registered: Nov-05 | so you think it will bump pretty loud or is it not that big of a deal |
Gold Member Username: RovinTrinidad & T... Post Number: 2651 Registered: Jul-05 | JL amps aree underrated & u don't have to match watt for watt https://www.ecoustics.com/electronics/forum/car-audio/174997.html ........ |
New member Username: A187sensesPost Number: 3 Registered: Nov-05 | so you think it will bump pretty loud or is it not that big of a deal |
Gold Member Username: RovinTrinidad & T... Post Number: 2653 Registered: Jul-05 | if u r so worried about matching the wrms then get orion 600D & buy the 4ohms dvc model of subs . Do get a Premier HU instead of that Alpine cause it has a higher preout voltage than alpine . Look @ the Premier DEH-P8MP or higher models .... .... |
Silver Member Username: CadillacdbHouston , TX Post Number: 188 Registered: Aug-05 | Take Superflys Advice ...... |
Silver Member Username: CadillacdbHouston , TX Post Number: 189 Registered: Aug-05 | Dont stay with a Stock Head unit |
Silver Member Username: TjmutlowPost Number: 192 Registered: Sep-05 | Stay with the 500/1 it is rated at 12volts and 1.5-4ohms load, |
