Amp Installation (rookie)
Username: Ciza
Belleville, Ontario Canada
Ok, i'm a complete virgin to audio installation so please bare with me. Ok my problem is as follows. I have a Blaupunkt GT450 amp which will be used to power my rear speakers and my sub. but my problem is my amp was bought by a friend in Germany, The problem with that is that the manual is in german. so i don't know what size inline fuse to buy. I bought a 50A for a 640watt sub, does that sound about right ?
Username: Tjmutlow
Post Number: 171
or try 60 you should be ok
Username: Ciza
if i go too high, what problems may arise ?
Username: Rovin
Trinidad & T...
Post Number: 2542
different manufacturers do thier own thing my new Alpine 545 does 125wrms x 4 & it comes with (4) 20A fuses .
maybe they have the answer here www.bcae1.com
no. 14 i think it is .....
Username: Ciza
hey superfly, the fuses your referring to, are they the fuses that plug directly into the amp or are they the inline fuses ?
