Will this amp work?? please help
Username: Odin367
Post Number: 21
I am looking at buying an RE SX 12". I was then looking at the hifonics brutus TX1000D. it gives 1000rms. Would that amp work with that sub? is that a good choice for around $200? if not, what about the titan TX1500D?? which one should i get? or should I get a diff amp? or can anyone recommend a better sub for about the same price?? but mainly, will either of these amps work good.? please help thanx
Username: Rovin
Trinidad & T...
Post Number: 2479
Hifonics are reported to do roughly 70-75% of advertised power
so i would buy the BX 1505D model - go google or ebat for lowest price .......
Username: Odin367
Post Number: 22
any other recommendations? should I buy the BX1505D??? will that work good enough?? or is there a diff amp around the same price that is good??
Username: Rovin
Trinidad & T...
Post Number: 2527
doubt u would get anything brand new 4 the price ....
